bcd 436/536
I900D658
sarnia
can anyone tell me why every time i download database weekly updates and download to my scanners i get database is corrupt and it won't download . if i force write to my 436 it works but does not work on the 536
iMONITOR
Silent Key
S.E. Michigan
Have you tried reformatting your Micro SD card? Also when you have the scanner in memory card mode, and not serial port mode, are you making sure saving data to the SD card has completed prior to removing the USB cable? Also are you remembering to 'Eject' the Micro SD card through Windows prior to unplugging the USB cable?
Ubbe
Stockholm, Sweden
Maybe it has changed with later firmware revisions but a year ago I tested 3 different brands and down to class 4 and I did not notice any difference between the different SD cards. Class4 are probably much faster than the scanner needs to use.
/Ubbe
I900D658
sarnia
436/536
thanks guys for your help i will a few of these and see if it works
