genej11
I need help programming a new BCD 436 Hand unit. Can this unit be programmed using Scan-lite Plus exe ?
Troymail
Yes I own that firmware however it does not show a BCD436 in it. I have programmed bcd396 bcd352 bcd996 etc. This is a first for the bcd436 and it did not come with the programming software. I would like to know how to get the software or where to send it to get it programmed. This is a christmas present for someone however it's no good if it's not programmed. It was purchased from Bearcat Warehouse, When I telephone them I get put on hold and left hanging or get disconnected.
Thank You in advance.
Troymail
Troymail
OK
I have done all the above.I will try to program using the instructions that came with the Sentinel Version. I assume that somewhere along the way it will allow me to go to RR and obtain the Frequencies etc.
OK
Update \ Update Master HPDB in the main program menu downloads database updates. Then Scanner \ Write to Scanner sends the updates (along with scanner settings and any Favorite Lists you've created) to the scanner.
" ...did it with this Windows 7 ... "
