EarlSuitor
For some time now I have been trying to figure out why the BCD 436 HP picks up other digital trunked systems so well and performs so poorly on the Loudoun Co, VA system. I believe I have found a $20.00 solution !! I have had several multi band antennae on the car and no luck..... so I got a 800 mHz cellular antenna (The Wilson Electronics Dual Band - 800-1900 MHz Magnet Mount Antenna with SMA Male Connector and 10-Foot RG174 Coax Cable) off Amazon for $20.00. It does away with the annoying popping & dropping issue many have complained about 98% ! I could pick up some transmissions all the way to Winchester and once in Loudoun I was impressed, very impressed. Evidently Loudouns system needs an 800 mHz antenna to work right. It still is marginal using the handheld antenna, but with this inexpensive rooftop groundplane 800 mHz antenna on the car it makes all the difference in the world.
BTW: What happened to the LCPS school bus LTR system? It went silent and has what sounds like ProVoice data channels coming off the Loudoun Heights site.
