BCD396T/BC996T: bcd 996t programming
vecher
PA
need to know how to program to receive the lancaster county pa system its a 400 mhz one
mostly 477 mhz i did create a custom rx . but will not lock on control channel
any help
Skip
Whiskey3JMC
Airwave Bandit
Southeast PA 🇺🇸
You may be within range of two or more towers on whichever simulcast you're tuned to. Have a read about simulcast distortion and steps you can try and take to mitigate it. Ultimately you'd be much better off using a Uniden SDS100 or SDS200 which were designed to cope with its effects but feel free to try the mitigation methods anyway, they may or may not work
Also bear in mind that all law enforcement is fully encrypted (as is every other mode "DE" talkgroup) and cannot be monitored
vecher
PA
the problem is it will not lock onto the control channel I can hear the control channel but it will not lock onto it
Skip
Whiskey3JMC
Airwave Bandit
Southeast PA 🇺🇸
Are you monitoring from within system coverage? Have you chosen the correct simulcast covering your area? Did you program by hand or did you use an app?
Enjoi19
Ontario, Canada
Skip
It's likely unable to get a data lock when it's dealing with simulcast distortion. Not much you can do about it - it either will work, or it won't. If you're intent on listening, it may be time to upgrade, or explore SDR options.
vecher
PA
ok I am not in the system coverage map.. but i can hear the control channel. so it should lock onto it i would think i am using freescan to program it. maybe i do not have the system setup corretly I need to know how to do that.
Skip
tvengr
Well Known Member
Baltimore County, MD
Lancaster County is a P25 system. It does not use a custom band plan. For the 996T, set the System Type to Mot Type II / P25. Set Site Type to Mot P25/P25 Standard. The band plan is automatically loaded from the control channel on a P25 system.
vecher
PA
