ProScan: BCD325P2 - Alpha Tags?
ProScan
Software Provider
Ontario, Calif.
Interesting, in my case the tags are ahead of the audio…
Perhaps, I was wrong on the text tags lagging the audio. But I still stand on the audio latency issue. The text tags and audio are sent out of ProScan in sync. The text tags are embedded in the mp3 audio stream.
emsflyer84
Central NH
Ok thanks.
emsflyer84
Central NH
Glad you got it working! I see the same experience when using an app on my phone or iPad. Tags are seen slightly "before" the audio. I use WinAmp when listening on a PC as the tags & audio are pretty much in sync (as noted by Bob). FYI - I tested your feed an don't see alpha tags being sent with the audio.
I tested it and they were working. I actually disconnected again to try some different things to keep the background noise down that is happening when I plug the data/charge cable into my PC. When it's plugged just into the wall to power the scanner there is no background noise. I'm going to try some different cables and see what happens. Thanks.
NYRHKY94
Brunswick County, NC
FYI - If you are sending Alpha Tags with your feed audio, it would be good to let Broadcastify users know about that. Go to the general details tab on your feed and check Broadcasting Alpha Tags. Once that is done, your feed listing will show a blue icon representing Alpha Tags are being provided. You can also add that to the secondary description under general details so users see it there too. Screen shot examples below:
