BCD325P2 - raw data output - what did i miss?
haimgil
Hello,
I was trying to test the raw data output on the Uniden BCD325P2.
• I went to Settings > Set C-CH Output > On
• I connected an audio cable from the scanner to a PC, hoping it will recognize the data signals coming out from the audio socket, like it does with Whistler`s TRX-1 (IF Output), but it didn`t go well. Am i missing something here?
kruser
Well Known Member
W St Louis Cnty, MO
Hello,
The control channel data is decoded in the radio and sent out the USB port but in a serial port data format.
It's not quite the same as a discriminator output which is what the TRX models are basically doing.
You can use a program like Pro96com to decode this type of data for P25 systems. Not sure if it outputs anything if you tune a trunked NXDN or DMR control channel though. Plus, Pro96com is only for P25 systems.
