Welcome to RadioReference.
In order to get the best answers to your question, please indicate your location (city (or county) plus state. Also, either provide a link to the database page for the system you are programming, or at least the name.
When you are seeing an interruption of reception, on a regular, repeating, basis. quite often it is because you have another function running in addition to scanning.
Having the scanner set to check Priority channels will cause this, as well as Weather Priority & running Close Call. Any of these can cause the scanner to briefly stop receiving the current channel to go check something else.
If you see "PRI" at the top of the scanner's display, just to the left of the signal bars, Priority is turned on.
If you see "WX" in the lower right corner, then Weather Priority is enabled.
A symbol that looks like the one below indicates that Close Call is enabled.
