BCD325P2 scan lists?
dgruver911
Newton, KS
Anybody in the Wichita/Hutch area knowledgeable with this unit and ProScan? Had a lady bring one down for me to program and I bit the bullet for ProScan because ARC-XT wouldn't work with it, and I cannot figure out how to set up scan lists for the 3 different counties she wants in it. Seems like it's all or none.
Ronaldski
MI DB Admin
Bay City MI
Since your a premium subscriber, download the free program, Freescan from the link at the top of the wiki page in the link below, download and install. If any windows popup comes up, just let it run. The main software I use.
Only thing is this software cant do is the DMR/NXDN formats for which highly likely isnt enabled in that radio.
Then take a look at the four videos near the bottom of the wiki. These were made before the 325P2, but program the same way so disregard anything about serial cables.
When you go to upload to scanner be sure to have the software search for the COM port always as is the case for all programming software.
When you get the info for each areas, just click on the site and select a different number for each area.
Also at Site Type in software, set it for P25 Standard.
tvengr
Well Known Member
Baltimore County, MD
I have no problems using ARC-XT with my BCD325P2. Did you install the driver for the scanner? Are all of the counties on the same or different systems? Which counties are you interested in? Here is a PDF file which will answer all of your questions about using quick keys to enable/disable systems, sites, and groups.:
  • Uniden Scanner Quick Key Instructions DMA.pdf
