This happens on every channel?loud continious tone when it stops on a channel.
TRY ENTERING YOUR LOCAL WEATHER CHANNEL TO SEE IF THAT WORKS.Any suggestions on what to check
Your caps lock is stuck on.TRY ENTERING YOUR LOCAL WEATHER CHANNEL TO SEE IF THAT WORKS.
I tried that it didnt work.Im stumbled ha!TRY ENTERING YOUR LOCAL WEATHER CHANNEL TO SEE IF THAT WORKS.
Thanks, its still under warranty .Im going crazy,ha! thanks for all the help I appreciate it.You were given a lot of suggestions back in your original thread:
Loud Tone Noise BCD325P2
Why does my BCD325P2 make a loud continious tone when it stops on a channel.It didnt do this before. Thanks!forums.radioreference.com
Since none of those worked, you probably will need to just send it back to Uniden to be checked and possibly repaired.
