Yes but apparently it's hidden.
P25 Threshold this is a hidden setting accessible only by turning off the radio and pressing Hold when you turn the scanner back on. |
| Scroll to 'P25 Threshold ' and press E/yes.
Scroll to Auto, Level 5-13 and press E/yes. |
No, that was on the older XT models and possibly early P2 firmware versions but it's always been in the standard settings part of the menu tree on all the xxxP2 models I've ever seen. And like I'd mentioned earlier, the P2 models also have a DMR Threshold setting as well. Also not a hidden menu item.
My P2 models were all purchased after a FW update or two had been released so it's very possible older firmware versions did still have the settings under the hidden menu which may be what you recall.
I've never seen it in a hidden menu on a P2 model though so you could very well be correct if it was still hidden in the early releases of the P2's.
I do know about the hidden menu you are talking about but on the XT models. It worked similar in how it works on the P2's as it was also a radio wide setting but I've only ever seen that on the XT models. It also did not have a true manual mode. UPMan explained the hidden settings for P25 in the later XT models and said the setting basically narrowed down the range the Auto P25 Threshold would search thru so the radio did not constantly search thru the entire range on P25 threshold settings trying to find the best one.
