BCD325P2 vs BCD436HP Close Call
UPMan
In Memoriam
Arlington, TX
Ideally you would inject two signals. One to provide a solid "floor" then slowly increase the 2nd frequency (in the same band) until it triggers. Close call triggers when a signal is a certain dB above either the noise floor or the strongest other signal in the band. In the real world, since an antenna can affect signal amplitude, an external antenna can affect close call range. One example from my experience is that I've never gotten a CC hit from an aircraft on an on-unit antenna but have gotten many on an external antenna. The antenna raised the target signal level much more than it raised the noise floor.
KevinC
Other
Super Moderator
Home
And if my radio didn't have this design flaw I would have never needed to know that information. :p
KevinC
Other
Super Moderator
Home
Bottom line is the missing cap C1/noise issue is a major issue and not "way overblown" as someone else stated.
scannersnstuff
Ok, I have a question. When my batteries were in the 436, I did not have a clock issue. I removed them, and stored away the radio, for about a month. When I repowered, I had lost the date/clock. Is this normal, if you have c1 installed ?.
jonwienke
More Info Coming Soon!
VA
That is totally normal. The tiny RTC backup battery only lasts a week or two if the main batteries are removed.
C1 has nothing to do with the clock, other than being on the same circuit board.
jonwienke
VA
For Close Call hits, yes. For regular reception, not so much, as long as the antenna is physically separated from the battery compartment.
KevinC
Other
Super Moderator
Home
jonwienke
VA
A Diamond RH77CA with the Uniden SMA-BNC adapter is sufficient, but you be you.
KevinC
Other
Super Moderator
Home
No Jon it isn't. I've done extensive testing on this. What would be sufficient would be if Uniden admitted that this is an issue.
And even if it did it would do "Zip. Zilch. Nada" for Close Call.
But you be you and keep defending Uniden no matter what.
KevinC
Other
Super Moderator
Home
In the words of UPMan...
When there is a problem, admit it as soon as possible.
Customers are not stupid. Ignoring or denying a legitimate problem is not the way to handle it.
If necessary, check with legal or senior management before commenting.
Never promise a fix you cannot deliver.
http://info.uniden.com/twiki/pub/publish/upman.html
KevinC
Other
Super Moderator
Home
Anyway, I've proven my point so I'm done here.
Thanks for playing along everyone. :)
k3fs
Western PA
I agree Kevin.
For regular reception the BNC adapter is not even close to being enough. You need a few more inches of separation of the antenna from the radio to clear this noise issue. I have used different methods to test this out. Aluminum or copper tape fixes UHF, but not so much VHF.
C1 fixes both of these.
Funny, how someone named Paul O. admitted to the issue on a local scanner group. Yet, there are others ready to deny this issue.
Close call hits have increased since I installed the C1 capacitor myself.
False advertising and not delivering what you promise are problems.
You loose credibility when you don't follow your own rules.
