bcd346xt
techues
Henderson, Nevada
Does this scanner have the ability, using Butel software, to set the volume off set so some channels aren't so much louder that others within a group?
Thank You
GTR8000
NY/NJ Database Guy
BEE00
I'm not sure if you're referring to the BC346XT or the BCD396XT, but the answer is "yes" to both. You can change it directly on the scanner as well, from -3 to +3.
techues
Henderson, Nevada
Thanks,
I tried to reset them for one group using the butel software that shows that colum but I didn't see a difference on the EDACS system. I'll try it again and listen closer!
kf4sek
Cocoa, FL
If you use AFS talkgroups mode, it doesn't work on wildcard talkgroups. That is, if you have 01---- instead of 01-011, it will work on the 01-011 talkgroup but not the 01---- talkgroup. At least, it doesn't on my BC346XT when monitoring my county's EDACS trunked system. To get it to work, you must enter each talkgroup separately (01-011, 01-012, etc) and not as 01----, 02----, etc. and then adjust each talkgroup as needed. Like I said, on my BC346XT it works like that....don't know about any other BC346XT. I hope this helps.
