BCD396t and MPSCS
ffexpCP
wizard of odd
Michigan
I’m listening to the MPSCS on my BCD396T with only one control channel programmed. Nothing else is programmed in. When it scans it shows the signal strength (usually 5 bars) and it shows DAT. But every couple of seconds it instantly drops all signal bars and the DAT display goes away. Then it comes back just as fast as I lost it. Is this normal for it? It looks like it’s flashing on and off. Will I end up missing anything when it looses signal like that?
And another question. When it shows LNK- is it listening to the radio that’s talking or is it listening to the tower that’s repeating it?
rdale
Lansing, MI
I don't think any of those links come anywhere near answering your question...
That is normal - it goes into a mode where it's ready to go to the next system so it prepares to move off the control channel. I've never noticed it missing anything side-by-side with a Pro96 so it is probably more a display thing.
If you don't want to see that, and only monitor one system, you can make the hold time to 255.
- Rob
seamusg
Grand Blanc, MI
- Rob
My Bc796 does the same thing if I put in tower 701.
rdale
Lansing, MI
Totally different scanner. Still has nothing to do with CQPSK.
