Voyager said:
Example 1 is not a P25 system. A P25 SYSTEM must have 9600 control channels and cannot have any analog voice at all. Zip. Zero. Nada. Name one 9600 system that has analog TGs. You won't find one.
Joe M.
Where does it say that a "SYSTEM" must be a trunked system. I design lots of systems for agencies, some are trunked, some are conventional, most are mixed to so extent.
Heck some are data systems.
You are making the mistaken jump, that the word "SYSTEM" means TRUNKED SYSTEM.
And yes you are correct, that the current P25 trunking control standard does not support analog voice channels. (I think I already said that.)
Voyager said:
Your second example is not a P25 system. It's a system that is only P16 compliant, but NOT P25 compliant. Even if PARTS of the system are P25 compliant, it must ALL be P25 compliant to be a P25 system.
Where do you get this strict interpretation? Have you asked for consensus from the TIA standards committee? :roll:
Since P25 is an evolving standard, does every P25 system all of a sudden stop being a "P25 system"when a new specification is added to the standard? :roll:
You have also jumped to the mistaken conclusion that P25 and P16 are somehow related. I can build a P25 system that is NOT P16 compliant.
P16 is a functional specification defining the minimum operational features for a public safety trunked system.
P25 is a suite of technical standards defining specifications for intercompatible radio digital radio systems.
Voyager said:
Your third example is the only one that is truly a P25 system.
Program your scanner based on the SYSTEM, not based on the fact that it may use P25 compatible voice channels. For the RR site, the line that matters, and the ONLY one that matters for programming a P25 scanner is "System Type:". If it says P25 standard, program it as P25. If it says something else such as "Motorola Type II SmartZone Omnilink", it's NOT a P25 SYSTEM.
Joe M.
Yes you are right. As I said before, you need to program your scanner according to the type of TRUNKING CONTROL CHANNEL a trunked system uses.
