Sipho
I have a BCD396T and the audio is not clear when trying to receive Phoenix PD on Simulcast A and also Mesa on Simulcast D as well as Gilbert PD.
I sent this radio into Uniden for repair and it came back after 3 weeks exactly the same. I've tried all the different settings as per manual on optimizing P25 performance. It only gets worse. Now not all transmissions are bad. Probably close to 20% are. They cut out or are distorted and sometimes sounds like overload. Other systems work and sound good.
I bought the RS 800mhz antenna and also have their base discone antenna and I've tried it in different locations as well. I can get 5 bars signal strength but the audio with the Phoenix trunk radio system is just not good. Other P25 audio from other sites are ok.
Question... Is this just the way it works here in Phoenix, or do I still have a bad radio?
Does anyone else have a BCD396T radio that listens to the Phoenix system and does it sound ok? Mesa and Gilbert PD and FD are dissapointing.
Question.... when I set up the system.. do I use Motorola P25 or Motorola Type II?
Maybe someone will clear this up for me.
Thanks for any suggestions
I'm in Gilbert
I'm in Gilbert
