BCD396T Can't receive London police.
oldtymer
Mount Brydges (near London) Ontario.
What do you suppose I am doing wrong or incomplete? I completely erased all the channels, groups, etc. from my scanner and then used the "ARC 396" software to download into my empty scanner the London Public Service (London Police - EDACS wide?). When I turn my scanner on I can see "main" appear, "dispatch" appear, "London ??" appear but I get absolutely no voice, burbble, static or anything. (squelch on #1 or #3 or #5) So I completely deleted everything again and used "FreeSCAN" software to download into my empty scanner the London Public Service frequencies. Again, the scanner shows London something in the window but will not stop on any channel. It just keeps scanning or searching. Can someone kindly advise me as what I should try? Thanx in advance, Oldtymer.
cpuerror
Ontario, Canada
Does the signal strength indicator light up? If it doesn't then it means you are not picking up the control channel. Also for EDACS make sure you are not in control channel only mode.
mciupa
Moderator
No scanner will work for London Police Service due to encryption. :(
torontokris
Toronto Canada
sorry you wont get them as mciupa said they are encrypted.
are the fire and ambulace still analog? try listening to them
exkalibur
York, Ontario
You won't have a problem listening to London Fire or EMS. They aren't on the Police EDACS system however.
London Fire is on it's own 800MHz Motorola Hybrid trunking sytem. London (Thames) EMS is on the BMR VHF Fleetnet trunked system. Both systems can be found in the RR Database.
Forts
Mentor
Ontario, Canada
As already mentioned, unfortunately London Police are unscannable (and have been for quite some time). They are using AEGIS digital with encryption (so a P25 scanner like the 396 wouldnt receive them even without encryption). They may have migrated to ProVoice at some point, but I don't think they have yet...
Jammin_Jay
The only time i heard london police when i was down there, was on OPC common, and also talking with the fire dept on a linked talkgroup. Fire also is simulcast on 154.725, but not all talkgroups will appear on that frequency. So it's best to monitor the trunked channels. And yes fire is still analog. For who knows how long is anybody's guess.
