BCD396T "ENC" question
robwilson
Baton Rouge, LA
Has anyone else experienced the "ENC" at the beginning of digital transmissions when it's not actually encrypted? It only appears briefly, then shows "P25". I seem to get this quite a bit on the Motorola Type II system that I monitor. Just wondering if anybody else has seen this. Could it be my settings or just something that the BCD396T is confused on?
Thanks,
Rob
DaveIN
Founders Curmudgen
West Michigan
Sometimes I see one side of the comm is encrypted and the other side is in the clear. Many times the conversation from the clear is sensitive information that I am sure should be secure. Perhaps the user does not know the encryption is not in use or has a bad code key, so on the 396 display I see ENC, then P25, then ENC again until the comm is finished.
mam1081
Next to a scanner...
If the user had a bad key (Key Fail), the radio will not TX unless the operator moves the toggle back to "clear", or to another mode.
There are like 2 or 3 bits in the whole P25 signal that tell the scanner if it's encrypted or not (and what key # to use). Maybe it just misses that part.
