BCD396T Help Needed Searching
james07731
Monmouth County, New Jersey
I have figured out most of it, but how do I program the searching?
Say I wanted to search between 150 & 160 mhz...I am having trouble figuring it out.
It was easy with the BC250D, I just Hit "search" entered the low & hi freqs...this one I'm still confiused.
All help appreciated. Thanks
davidmc36
South East Ontario
Give this a shot. A little more than halfway down the page is a section with a green header: "Editing a Custom Search" It is pretty step by step on how to set it up.
Easier to Read BCD396T/UBCD396T Manual
Actually I see the way that link is written it takes you almost to the right spot, just scroll down a few lines.
very easy just go to edit custom search then edit what you want then hit custom search and then hit the number you customized
edit the way i do it is i remove 1-10 then i can pick a number to go to as i have set all 10 to different scans
