yelmarb said:I'm aware that this scanner is not sold in the UK but I'm wondering if there are any UK owners and if so have they been able to pick up any other transmissions that an analogue scanner would not pick up?
morfis said:There aren't many systems that you can use the "trunk tracking" on as most trunked systems outside the USA use other protocols.
The bandplan on the 396T comes in two (I think only two) flavours, neither of which is much use in the UK. It is not user configurable.
Why specifically one of these? According to a few people the 3500 is the best thing since sliced bread and almost has a Uk suitable bandplan. The "close call" certainly seems better on the 3500 than on any of the US model Unidens I've used (so far!)
Lodis said:The reason why I am looking at the 396T is because I am looking for a portable Trunking scanner. I have had a Uniden 780 XLT Trunk Tracker III (EU) Base Station for quite some time now and this is excellent for Trunk Tracking but I do want to get a portable that can do the same as this.
I am not sure if the 396T can though, the 780 XLT has Trunking capabilities: Motorola, EDACS, LTR, doesn't the 396T have these as well?
morfis said:Yes but in terms of what is publicly discussed there is no LTR in the UK, five Motorola nets and three EDACS nets. It's an expensive radio just to monitor a couple of these...and as you'd have to travel around to monitor all of them a handheld probably doesn't offer much advantage over your 780.
The 396 will allow you to monitor a few APCO P25 channels that your 780 won't.
The 780 IS a portable scanner.
Lodis said:Thanks for your input Morfis, it is very appreciated. I am interested in where you got your 396T.
Lodis said:I hear the Butel ARC396 software is good for this one and although the bandplan is fixed in the actual radio apparently you can setup a bandplan in the software. I am assuming this is just the custom search ranges and step settings though.
Lodis said:You are correct that it would be an expensive radio just to monitor a couple of those channels.
Would you purchase this radio again if you had a second chance or would you instead go for a different one?
morfis said:The review seems to be mostly a re-hash of his other efforts mixed with a bit of cut and paste from the sales info....which radio are you now talking about as he obviously can't remember what he was "reviewing"?
I've had no problems with the 396T on any of the UK systems.
Lodis said:I am talking about the 396T so im glad to hear you haven't had any problems with this on any of the UK systems.
morfis said:hh. wasn't actually questioning you just Melv's "review" of the 396T where he has cut and pasted his comments from an earlier "review" and forgotten to change the model number.
yelmarb said:I'm also picking up some interesting trunked systems. However, they're not listed (in the database) and hence I'm having troubles trying to figure out how to program the system from scratch. I've noted down a broad list of frequencies and what could possibly be a few control channels. I now just have to put them all together. Any idea how?
tbone_69 said:http://www.radioreference.com/modules.php?name=RR&sid=910
I have just moved from the USA to the UK with my 396 in tow
Can anyone give me advice on how to load the above trunked scheme ?
