BCD396T Question
wjf
Witness Protection Program
Scenario: A friend says "Hey, check out TG XXXX right now", and it's not already a TG programmed into your scanner.
Is there a method to directly enter that TG temporarily, without having program it into the scanner?
Can't find it in the manual.
Thanks.
dtscho
Fredericksburg, VA
Make sure that you're ID scanning/ID searching the trunked system that the talkgroup is on. Press HOLD, then enter the talkgroup, and then press HOLD again. When you want to go back to scanning/searching, press SCAN.
Dave
wjf
Dave
Perfect! Thanks a lot, Dave!
wjf
