BCD396T Search/CloseCall Autostore
John_M
Rochester, N.Y.
When you select a system to autostorethe frequencies, in which group does the autostore put the frequencies. Do you have to press the Knob to store the frequencies?
John_M
Rochester, N.Y.
Update:
1. During search and store the scanner stops on a frequency that breaks squelch (Not displayed on the scanner). You can't hear the transmission.
P.S. (You can set the autostore to skip data transmissions).
2. Does a memory check and stores the frequency into a group
called "Found Channels" in the conventional system that you selected to put the autostore frequencies in.
For ID Search and store. The scanner does the same thing. Creates a group called "Found Channels" in the trunked system you selected and stores all ID's in that group.
