AJ4VS, it sounds to me like the problem is that the P25 Waiting Time is set to 100 ms or higher on the site(s) that you are trying to monitor. This would cause the exact problem that you are describing. RickLeb mentioned that you should look into this possibility in his earlier post, but I didn't see you (the OP) address whether or not you verified that the P25 Waiting Time is definitely set to 0 ms on each site that you are monitoring. Even if you think the P25 Waiting Time should not be a problem since the audio is set to analog only, you should still check out what the P25 Waiting Time is set on for each site in the system that you are having problems with to ensure that is not your problem.
When I program a site for a trunking system that is not a pure P25 system into my BCD396XT, the P25 Waiting Time is always set at a default of 400 ms for each site. This delay of 400 ms will always cause a delay in the audio because the scanner will wait 400 ms to try and detect a P25 signal (even if you are monitoring an analog system) before any audio will be heard. I always turn the P25 Waiting Time to 0 ms to prevent the exact problem that you are describing. You should definitely check to ensure that your P25 Waiting Time is set to 0 ms, which will ensure that there is no delay in allowing you to hear audio. The P25 Waiting Time can be changed by selecting a site in the system that you want to change the P25 Waiting Time for and scrolling down the menu until you find the P25 Waiting Time option, then simply set it to 0 ms. You will have to make that change for every site in the system that is giving you problems.
I have a strong suspicion that the P25 Waiting Time is set to 100 ms or higher (it's probably set on the default 400 ms) on each site that is on the system that you are experiencing problems with and that setting the P25 Waiting Time to 0 ms will fix your problem. I hope this helps you and I wish you the best of luck in trying to fix your problem. Let us know if this turns out to be the problem.
I checked and you are correct, the p25 setting was not at 0. I changed to 0 like you said. Unfortunately, the problem still persists. I really like the features and size of this radio, but I'm starting to feel discouraged in using it. I really don't want to, but it seems like my pro-106 is still going to be my daily radio :-(
