BCD396XT/BCD996XT Code Search
feenjo
Norwich, CT
I have numerous conventional frequencies stored that I have not heard anything on yet. When I search using either scanner, if the search settings are set to use CTCSS/DCS Search, will I not pick up on any digital comms? Also, vice/versa, if it is set for NAC Search, will I not get any analog hits? Along the same idea, if I have a conventional frequency set for CTCSS/DCS Search, will I get any comms at all if it is actually digital? Again, vice/versa, if I had a freq set for NAC Search, will it not stop if there is analog comms?
Will I have to duplicate all the unknowns and set one for CTCSS/DCS and the other for NAC Search?
Thanks ahead for your input.
rbm
Upstate New York
The BCD396XT and BCD996XT have only one decoder.
It can be used to decode digital 'or' CTCSS/DCS but not both at the same time.
When you program for NAC search, it programs the scanner for digital mode ONLY.
When you program for CTCSS/DCS search, it programs the scanner for analog mode ONLY.
If you program it to NOT search for 'either' NAC or CTCSS/DCS it will receive BOTH digital and analog.
Rich
feenjo
Norwich, CT
Thanks, Rich. I was not thinking that I could easily search frequencies without a code search, then when I hear traffic, I can track further and check for analog or digital.
I appreciate the reply.
