Does anybody have improvements decoding CQPSK/LSM on 9600 systems...?
Jacob
Update
I just went to a different computer that has never had any Uniden software installed on it.
I installed the USB to Serial DB9 drivers ...OK
I downloaded BC_VUP Firmware Loader and the new firmware file.
Got the exact same results...Error when trying to install.
Now i am really stumped.
Thanks for the above post however it still doesn't work.
The only thing that is different is the Baud Rate of the COM port in Device Manager defaults to 9600 where the BC_VUP program defaults to 115200. The BC_VUP program will not go down to 9600.
I've tried leaving the COM port at 9600, i've tried 115200. Nothing makes a difference.
I still go back to my original assumption. I can communicate with my scanner using FREESCAN with no problems at all which tells me my COM port is working fine at 9600 and my cable is working fine.
When i being the installation it says 'Communicating....', then switches to 'Erasing...' then errors out.
That indicates to me that it recognizes the scanner but it won't Erase then Upload the new .scn file.
I've tried downloading the .scn file multiple times. I don't know if the .scn file is corrupt during download or there is another issue. I can't believe that i have 2 separate computers exhibiting the exact same problem.
I am a software developer so i am trained to deal with these types of issues which make me think there is a problem with the software. However, since there are users who have already downloaded and installed the update with no issues it still leaves me scratching my head.
Did update went all right when I moved the file unless I have a wrong setting thier is no change
When you set the com port to115200, Does freescan work at 115200? I use115200 for everything and I don't have any issues.
DDan,
When i go into Device Manager and change the Baud Rate of the COM port to either 9600 or 115200 i can access my scanner with FREESCAN with no problems.
One thing that I've seen more than once was the Win 7 built in firewall was blocking something even on a serial connection.
Once I turned the firewall off, my upgrade went fine.
Just make sure you are behind a nat router or better yet, unplug the ethernet cable before you kill the firewall.
Granted, I did the 396 and 996XT upgrades just fine today without killing the firewall. I've not needed to kill the firewall in Win 7 since it was about one or two months old either.
That one was an odd one and why the firewall had an effect on the serial port comms is beyond me but it did is all I know. I clearly recall things starting to work and then quit half way through like you seem to be seeing so you may want to try that and rule it out as a possible cause.
I think your updating the 396XT, are you following the directions, taking out the batteries, holding the two keys and plugging in the AC adapter like the directions tell you? I'm sure you are I'm just checking...
You are not trying to use the rear port of the scanner are you?DDan,
from this thread: http://forums.radioreference.com/uniden-scanners/160896-bcd996xt-rear-port.htmlYes, the rear port can be used for everything except firmware updates.
Sorry, somehow I didn't notice that you said that you had 396XT.I have the 396XT not the 996.
One other thing that may or may not be important...
I am using the Prolific USB-to-Serial Cable in Windows 7 Pro. The driver version of the COM 3 port is 3.3.0.1 (1/31/2008)
Wondering if anyone else is using this same driver. I can't find a newer driver online. But again this driver works communicating with my scanner in FREESCAN with no problems.
