BCD396XT - Houston, Texas HPD, HFD
Houbob03
Houston, Texas
Hello All,
I was a big scanner back in the crystal days and just last year it appears that Houston switched systems and my old analog scanners became silent. After saving up, I purchased a BCD396XT last week and promptly joined Radio Reference.
I had read the forums and some posting on the NEW programming nightmare I was about to embark upon and decided to follow the suggestions:
1. Join Radio Ref.
2. Download Proscan
3. Download Database
4. Program scanner with upload.
I went through this and all went very smooth just like the advice. Only problem is nothing is heard. It is scanning and I see the channels in there, but it's silent as my analog. I am sure I have missed something or done something wrong. I would appreciate any advice or help anyone can give me. I love listening to police in my area to know whats going on around me so I have invested heavily with this equipment and would just like to get it to work. Thanks in advance!
-Bob (Houston, TX)
KevinC
Moderator
Super Moderator
Somewhere other than home :(
It looks like you don't have any of the trunked information entered, only conventional and most of that is simplex AND encrypted.
What part of town do you live in and what do you want to listen to?
I'll make you a file as a sample and you can massage as you seem fit.
KevinC
Moderator
Super Moderator
This is very basic, but should get you headed in the right direction.
Be sure to save your current configuration first in case you don't like what I attached.
Houbob03
Houston, Texas
Thanks. How can I import this? When I try clipboard, I copy but nothing pastes. Anyway to point to the file in proscan?
Houbob03
Houston, Texas
I think its working, got up and unplugged it, turned off and on. Then started hearing traffic. Seems like its all good! At least now I can hear stuff while I educate myself more. ; )
Thank you for taking time to help a newbie. I do appreciate it and I hope this helps others as well.
-Bob
infohou
Houston, TX
Can't Open Com 1
Hey Folks,
Bought the 396XT yesterday but I cannot get a serial connection to Proscan. I am an IT Consultant of sufficient age to have worked with many serial connections. I have set the radio to match the comm port speed of the computer and gave Proscan the same speed. I am using the rs232 port and have tried several speeds.
On the 396xt does it need to be in GPS receive mode or not? The comm port on the computer does not show any additional drivers, should it?
Thanks,
Robert
PS: Thanks to KevinC as I am planning to use the config he posted in this thread.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Nope you don't need drivers if you really do have a serial port on that PC...assuming here that you know that new PCs don't have serial ports anymore...anyhow, one step you didn't mention was configuring the port on the scanner itself. This wiki article has a summary of how to go about it for all the DMA scanners...
Freescan - Connecting Scanner to PC - The RadioReference Wiki
Another thing to check is Device Manager -- see if something is grabbing COM1 and won't let it go....
GL...Mike
infohou
Houston, TX
"assuming here that you know that new PCs don't have serial ports anymore"
Yep, as I said, I am an IT Consultant.
"...anyhow, one step you didn't mention was configuring the port on the scanner itself."
Actually I did mention "I have set the radio to match the comm port speed of the computer" .
"This wiki article has a summary of how to go about it for all the DMA scanners..."
That is good info!
"Another thing to check is Device Manager -- see if something is grabbing COM1 and won't let it go....
GL...Mike"
Good idea, I have already done that.
Thanks for the Wiki link and your reply. What I don't think I did was Yes after selecting the speed on the scanner. I just push the rotary knob in and thought that would select it. I will try that now.
I appreciate the help,
Robert A. Ober
