What is the best/quickest way to directly access a channel on a BCD396XT when number tags are NOT used.
On the 396T, the method was to hold down the Function key, then press 7 on the key pad to enter the "Recall" function. At this point, a System name was displayed and you would then rotate the scroll knob to display the various systems, then press "E" to select the desired system. Then the next step was to repeat the process by selecting a group in that system, then selecting the desired channel within that group.
What is the best way to achieve this same functionality in the BC396XT? Function / 7 on the XT activates the attenuator feature.
I know you can select a system by pressing Function, then rotate the scroll knob, but that does not let you drill down to the group and channel.
Thanks.
Thanks.
