I'm sorry and disappointed to say that the 396XT still suffers from multipath distortion and drop-outs to a much greater extent than the PSR-500. It is an improvement in this area over the 396T and the 996T, but it doesn't even come close to the PSR-500/600. I wish it did because it has more, "cooler" features and more memory. It is smaller and lighter and has a beefier belt clip. I also prefer the Uniden memory scheme. But like its predecessor, the 396XT doesn't measure up to the GRE's when it comes to multipath correction.
Not everyone is ever going to notice this problem, admittedly. But anyone who moves around in an area served by simulcast digital systems is very likely going to. I happen to live in multipath hell. I'm smack between two towers on the local system I listen to and about 35 miles equidistant from 3 towers on the other system I listen to frequently. On the 396XT, no amount of tweaking will get rid of the drop-outs and distortion, even though the signal strength is a steady 5 bars. The GRE's operate with no distortion or drop-outs right out of the box. The difference is somewhat astounding. However, I can move the 396XT a couple of miles away and all the problems go away. Of course, in travelling around I can find many other places where multipath causes problems with the Uniden. But since I happen to live in one of them, it is truly annoying...and disappointing.
I can also say that at least with stock antennas, the PSR-500 is picking up distant 800mhz systems much better. On the roof 800mhz antenna, they seem about the same so it may just be that the stock Uniden antenna isn't tuned as close to 800mhz as the GRE. But just to reiterate, the multipath issues are completely independent of signal strength.
