I usually get these things figured out myself but, this one has me stumped so, tia.
I have a Uniden BCD396XT that I've had for the last year or so. It's been fine and I've made no recent changes to programming or settings.
For about the last two weeks I have been having a problem with one Motorola Type II Smartnet group in Franklin County OH. Franklin County Public Safety Trunking System, Columbus, Ohio - Scanner Frequencies
Several of the channels after a transmission ends will "stick" i.e.. it appears that it doesn't close squelch and all I hear is smooth static, very much like an open mic. This happens even with squelch turned up to full.
Most times this resolves on it's own and resumes normal scanning. Sometimes I have to press scan to leave the channel and nomal operation resumes. It's not consistant or predictable and it doesn't happen all the time.
(for reference I have copied some of the offending channels from freeSCAN)
Display TGID L/O Pri AudioType Comment
SheriffDispeast 11248 False False All
USMarshalService 11088 False False All
10480 Display TGID L/O Pri AudioType Comment
MetroEMGCommunic 10480 False False All
I can also get scanning to resume by wrapping my hand around the antenna which to me suggests some outside interference but nothing I'm aware of has changed at my location and it happens anywhere in the house.
I can negate the problem by setting a negative delay for this group but then transmissions are clipped and I miss a lot.
If there's any information that would be helpful that Ive left out let me know.
Thanks for any insight.
D
D
