so I take it you do not have a serial port to plug the cable into? If you do, you can capture a file and post it. We can look at the file though you seem to be checking everything . FM broadcasts should come in, you should see a signal strength indication on the upper right corner.What antenna were you using before the batteries were removed? Did you remove and reinstall the antenna.? There is a center pin, did it break off?
