I just received my scanner really new to it.I used a program called freescan to program the scanner which failed.I now do not have external speaker I only have headphone only is there a way to turn on the front speaker?
All I want is for my scanner to work like it should?
Everything is working great.The biggest problem I have is the speaker?
If I use freescan and shut off the send custom radio setting.
When I use the setting it generates an error.
I have tried to call and call uniden you try it you will see thank you for calling and they hang up on you
