hi
I am trying to setip a trunk system search for the new Seattle , KING County KSERN System. I enter the system name in trunk discovery mode, the radio comes back with no system found. I am using the latest database as of this week, and my firmware is up to date.
Any thoughts
Zach K7LTF
Have you got the ‘KING County KSERN System’ set in 1 of your favourites lists with a site. It has to be in 1 of your favourites lists to setup Discovery for the trunking system.
Make sure the favourites list with ‘KING County KSERN System’ is loaded and active when you start Discovery or it won’t search.
The go to Discovery via your menu.
Click on Trunking Discovery and then click on ‘New Session’.
Then input the Systems name ‘KING County KSERN System’ then the scanner will find the System automatically.
Usually you will only have to type in the first or second letters and your scanner will still find the System. If not type the whole name.
Add the site then press yes.
When you have found the System in Discovery, click on it and set Logging to all so it will Discover all TGID’s.
(When I use Discovery on 1 of my P25II TRS systems and because I have many TGID’s already loaded I set to FIND NEW. So it will only Discover new TGID’s and NOT duplicate TGID I already have loaded. Yes I can do a ID SEARCH while scanning the P25II TRS but because I like to check for new TGID’s when I’m not at home)
I have set Record Duration to 600sec because I use this feature when I’m at work and leave scanner on all day to find new TGID‘s I have not loaded.
I then set Time Out Timer to 10sec for when the the scanner gets hung on a Control Channel or similar.
Set Auto Store to ON, so it stores Discovered Channels.
Once you have done all that go back to Start Discovery.
I think this is all you need. I haven’t set up a Discovery search since I first got my 536. Any problems let me kno.
IMPORTANT:
Goodluck.
