BCD436HP/BCD536HP: bcd436 and restricted acess dmr
ronenp
Can the BCD 436 listen to restricted access DMR conversations ?
If no is there any scanner that can ?
Thanks Forward
R
fxdscon
¯\_(ツ)_/¯
Thanks Forward
R
What do you mean by "restricted access"? Are you talking about encryption?
BC_Scan
Vancouver BC
RAS ? we have numerous systems like that , No cannot hear them ENC will show on screen
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
That's odd, I can monitor RAS enabled systems just fine.
RAS isn't voice encryption, it's access authentication to keep unauthorized radios off a system.
JimD56
KO9JAD/Retired-Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
My high school runs DMR with RAS, which is Motorola Proprietary, and you can not hear them, but "E" does not show on the screen of either my SDS200 or my TYT MD-380 UHF DMR handheld.
ronenp
Thanks for the answers
for clarifications : RAS is NOT encrypted voice
So Is anyone here have BCD436 and can hearwith it communications on RAS systems ?
and if not is there any scanner that can ?
and for the answer that it is not an issue for any scanner does it include (tested on ) bcd436 ?
Thanks forward
R
racingfan360
Just to be clear RAS and encryption are NOT the same thing: Motorola systems can run RAS without encryption and DMR systems can run with encryption but not RAS.
I have successfully used a BCD436HP, TRX1, AOR DV10 and discrim tapped scanners with DSD+ on Moto systems running RAS.
Ubbe
Stockholm, Sweden
Whistlers TRX scanners can only decode RAS systems in conventional mode, there's a special flag for it that needs to be enabled, but that option are missing from trunked systems. The TRX-E firmware have no RAS capability and Whistler said they forgot about it and would add that in their next upgrade, but then they closed down software development, at least temporary.
/Ubbe
