What do you set the Battery Low Voltage setting at? Anyone setting it below the default 3300 (mV).
K kimbertown Member Joined Oct 1, 2016 Messages 16 Location St Louis, Metro East Jan 1, 2017 #1 What do you set the Battery Low Voltage setting at? Anyone setting it below the default 3300 (mV).
jonwienke More Info Coming Soon! Joined Jul 18, 2014 Messages 13,416 Location VA Jan 1, 2017 #2 I set it to the minimum to get the most battery life.
Theo Member Premium Subscriber Joined Dec 19, 2002 Messages 229 Location New Port Richey, FL Jan 1, 2017 #3 jonwienke said: I set it to the minimum to get the most battery life. Click to expand... That setting would be?
N9PBD Member Premium Subscriber Joined Aug 24, 2003 Messages 535 Location Southern Illinois (Metro St. Louis) Jan 1, 2017 #4 The lowest setting you can use on the BCD436HP is 3100 mV, so use that.
Theo Member Premium Subscriber Joined Dec 19, 2002 Messages 229 Location New Port Richey, FL Jan 1, 2017 #5 N9PBD said: The lowest setting you can use on the BCD436HP is 3100 mV, so use that. Click to expand... Thanks!
K kimbertown Member Joined Oct 1, 2016 Messages 16 Location St Louis, Metro East Jan 1, 2017 #6 Greg, Thanks for the reply. I also live in metro east St. Louis - Madison County.
