I have a BCD436HP and I am trying to use RH77A antenna with an sma connector. It doesn't seem to fit the sma connector on the scanner. Any suggestions?
Scanner is male and antenna is female. Works fine with the supplied antenna but the RH77 A is also female. It just doesn't want to screw on. Must be doing something wrong.
That's odd as my 436 has a female on it (and yes, I'm 1,000% sure about this ). But I guess that's neither here nor there as long as you have opposite sex pieces it should work fine.
