I'd like to be able to adjust the time on the delay during scanning. So I don't miss call backs. 2 seconds is just not enough time. The ability to adjust from 2-5 or up to 10 would be great.
You can change the hold time just go to the menu then delay and choose how long it will hold after an activation.
Voyager: Is the delay time adjustable in the unit? Or only in the Sentinal software?
OK cool! Got it thanks! Looks like it will keep me busy for a while! Just wish I could just do it once! Instead of every channel!
I would like to see a forced resume (0-second negative delay) as part of the delay menu. That way you could set up multiple times/NAC on consecutive channels and it would skip past the more active ones and alert you to less-frequently used ones. Discovery mode works in a similar way except it can't handle scan lists and is limited to a single search range. And tone skip only handles one tone to skip.
No, I'm talking about it stopping on a channel that decodes the "skipped" tone and immediately resuming the scan cycle. The purpose of my original idea was to be able to skip past identified users and only alert on new users, however I don't believe I have thought the logic through on this all the way since the identified freq/tone would still open squelch on the following channel that has Tone Search enabled. So what I'm asking for is possible, however in hindsight I don't think it would actually help solve the problem. Still considering how to accomplish this task other than Discovery Mode....Just so I understand what you are asking for... You want the scanner to move on from a channel programmed with a tone/code before determining the tone/code used. Is that right?
