BCD436HP/BCD536HP Serial Mode Windows 8.x Drivers
stubbe
Richmond Michigan
Windows 7 Drivers
Is there a link to the serial drivers for Windows 7?
I get an error when trying to connect my HomePatrol, BCD436 and BCD536
Steve
stubbe
Richmond Michigan
Every time I connect it to the pc as a serial connection I get an driver error and if you look at the device manager, it shows a problem. I have uninstalled and reinstalled the software....no luck.
miccona
Tampa, FL
not sure whats going on usually if you uninstall then install it again usually that will do the trick...........what kind of error are you getting in device manager??
mciupa
ELBOWS UP, CANADA
Moderator
I'm here a lot
I was repeatedly struggling with this until I read in one of the thousands of 536 threads that if you download the drivers to your desktop screen then browse on your own rather than letting Windows search for drivers it will load from that location.
That did it for me and now the drivers are on COM8 (in my instance).
Dafe1er
Off in a far away place, far from u.......
Funny I never loaded the drivers.
I am using a Asus Laptop that is a year old running Windows 7 and use it to program my HP-1. I took the 436 out of the box yesterday set it up and plugged into the PC with no issues. Loaded my favorites and off I went.
Maybe the drivers are the same between the HP-1 and x36 units? I do not know.
But all was plug and go from the start yesterday when I got the 436. Never asked for drivers or even had to look for them.
MesquiteWx
Texas
The drivers are for the serial connection. If you are just connecting to the device for the SD card windows will usually find and install that driver for you. If you plan on using the serial connection you will need the driver for the serial connection.
rdesilets711
Connecticut
I did find the 536 driver but I need help on how to install the driver. When I unzip it I see no .exe file. All I see is :
; Uniden
; Communication Device Class
; Virtual Serial Port
; 1/1/2014
[Version]
Signature="$Windows NT$"
Class=Ports
ClassGuid={4D36E978-E325-11CE-BFC1-08002BE10318}
Provider=%MANUFACTURER%
LayoutFile=layout.inf
CatalogFile=%FILENAME%.cat
DriverVer=01/01/2014,1.0.0.0
[Manufacturer]
%MANUFACTURER%=DeviceList,NTamd64
[DestinationDirs]
DefaultDestDir=12
; Windows XP/Vista32/7_32/8_32 Support
[DriverInstall.nt]
include=mdmcpq.inf
CopyFiles=DriverCopyFiles.nt
AddReg=DriverInstall.nt.AddReg
[DriverCopyFiles.nt]
usbser.sys,,,0x20
[DriverInstall.nt.AddReg]
HKR,,DevLoader,,*ntkern
HKR,,NTMPDriver,,%DRIVERFILENAME%.sys
HKR,,EnumPropPages32,,"MsPorts.dll,SerialPortPropPageProvider"
[DriverInstall.nt.Services]
AddService=usbser, 0x00000002, DriverService.nt
[DriverService.nt]
DisplayName=%SERVICE%
ServiceType=1
StartType=3
ErrorControl=1
ServiceBinary=%12%\%DRIVERFILENAME%.sys
; Windows Vista64/7_64/8_64 Support
[DriverInstall.NTamd64]
include=mdmcpq.inf
CopyFiles=DriverCopyFiles.NTamd64
AddReg=DriverInstall.NTamd64.AddReg
[DriverCopyFiles.NTamd64]
%DRIVERFILENAME%.sys,,,0x20
[DriverInstall.NTamd64.AddReg]
[DriverInstall.NTamd64.Services]
AddService=usbser, 0x00000002, DriverService.NTamd64
[DriverService.NTamd64]
ServiceType=1
StartType=3
ErrorControl=1
; company's information *
[SourceDisksFiles]
[SourceDisksNames]
[DeviceList]
%DESCRIPTION%=DriverInstall, USB\VID_1965&PID_0016
%DESCRIPTION%=DriverInstall, USB\VID_1965&PID_0017
%DESCRIPTION%=DriverInstall, USB\VID_1965&PID_0018
%DESCRIPTION%=DriverInstall, USB\VID_1965&PID_0019
%DESCRIPTION%=DriverInstall, USB\VID_1965&PID_001A
[DeviceList.NTamd64]
[Strings]
FILENAME="Uniden_usbser"
DRIVERFILENAME ="usbser"
MANUFACTURER="Uniden Corporation"
INSTDISK="USB2UART"
DESCRIPTION="Uniden Serial Port"
SERVICE="Uniden Serial Port Driver"
FYI: I use windows 7
Help me fix my driver please
UPMan
In Memoriam
Arlington, TX
Plug in the cable. When prompted by the operating system, point to that file.
If you are not prompted, open device manager. Go to the device in the list (if it isn't working properly, there will be a triangle/exclamation mark next to it), right-click to Properties, then update driver and point to that file.
rdesilets711
Connecticut
All set Upman
Thank you for info as I did locate the file and entered it into correct drive. All I need now is to be able to use the rear RS232 instead of front USB.
