BCD436HP FleetNet programming
balou
ontario
Hi guys, I'm totally lost. I'm looking for someone who could create a file for Zones 1-4 in different banks. I can pay. I can’t seem to figure it out in Sentinel.
gary123
You do not need all 4 zones unless you are travelling all over the province. This would create a complex codeplug for your scanner. What zone do you really need? Even then I would only use the towers around your location and limit the TG list to users on those towers.
torontokris
Toronto Canada
Agreed. Believe poster is/was "in Kapuskasing Zone 3" based on other posts
The 436 HP already has all 4 zones in the Full Database so can be scanned without programming it. Set location enter postal code (open service types to deserted service types). And hold on Bell FleetNet system
If you do drive all 4 zones you can hook a GPS to it and it will scan as you drive
balou
ontario
Thanks, yes Zone 3. I do travel quite a bit. I tried my postal code, but all I get is the analog 410.8625
balou
ontario
Thanks. I put in my postal code but after that I'm not getting anything. What am i missing? Should I see anything that says FleetNet or just OPP?
I see a few things OPP, but don’t hear anything.
Is there a way to activate the P25 system?
balou
ontario
I got it, thanks guys. I was sure my range was set but I guess it didn’t save. Back at 50 miles and it works.
