Thanks for the all the info, you helped me and my BCD436HP out a bunch.
I purchased the Rosewill RCW-109 cable and a Startech C9PSM DB9 male connector, for connecting my Uniden BCD436HP and Garmin Rino 110 GPS(which has DB9 female connector)and verified it works.
I would testing/verifying the continuity of wire colors and terminals at the Mini B connection before soldering to the DB9 Male, this thread post:
http://forums.radioreference.com/un...ive-uniden-programming-cable.html#post1628266
seems to use the same Rosewill cable yet used different colors for the connections.
For my situation, After cutting the USB A male off of the RCW-109 cable, I found/tested the following:
Black wire was pin 1 on the Mini B connector
Green wire was pin 2 on the Mini B connector
White wire was pin 3 on the Mini B connector
Red wire was pin 4 on the mini B connector
When soldering to the C9PSM DB9 Male connector, I connected the wires as follows:
White wire to pin 2 on the DB9 connector
Black wire to pin 3 on the DB9 connector
Red wire to pin 5 on the DB9 connector
Green wire is not connected.
Now I don't have to use my 396XT's cable and null adapter/gender changer thingy. Thanks.
