pstewart675
Just got my first scanner (Uniden 436HP) and was picking up all my local frequencies (pd, fire, etc.) and now not picking up any of them. What am I doing wrong?
It's like asking my car doesn't run - what's wrong?
You need to give MUCH more information in order to get any help.
I see Bowling Green, so should we assume the issue is there?
What are you trying to listen to?
What did you change - if anything?
Did you have an electrical storm?
What antenna?
Does it pick up anything? (try the WX)
Etc...
Etc....
Yes, I have sentinel and firmware is up-to-date.Do you have Sentinel, free programming software provided by Uniden? You will need it for updating the firmware and database. Here is the link: BCDx36HPSentinel < UnidenMan4 < TWiki With Sentinel, you can also attach your favorites lists files so that we can check them for problems.
I am in Bowling Green, KY. Trying to listen to local police, fire & EMS. When I first got the scanner and setup a favorites list, it was picking up all three well. It now picks up no frequencies from any of those agencies. I setup a new favorites list in sentinel and uploaded it onto the scanner but still not luck. No electrical issues, stock antenna that came with the scanner.
FAVORITES LIST QUICK KEY: | |
0. Warren Co KY | |
SYSTEM QUICK KEY: | |
0. Warren Co KY | |
DEPARTMENT QUICK KEYS: | |
0. Warren Govt Svcs | |
1. Warren Interop | |
2. Warren Emerg Ops | |
3. Warren Fire | |
4. Warren EMS/Hosp | |
5. Warren Sheriff | |
6. Bowling Grn DPW | |
7. Bowling Grn Fire | |
8. Bowling Grn PD | |
9. Western KY Univ |
Download and Monitor are not in the favorites list. They are under the Scan Selection tab of the profile. Download and Monitor are turned on and off in the profile.When you created the Favorite's List, sometimes sentinel software will turn off "Monitor" for that list by default. Go into your Favorite's list and turn "Monitor" back on if it is disabled.
Thanks for pointing that out. I hadn't noticed it. Unfortunately, you can change only one favorites list at a time. I have hundreds of favorites lists.If you right click on the System in the favorites list it can be toggled ON/OFF (See attachment)
Did you try the favorites list file in post #11?Just got my first scanner (Uniden 436HP) and was picking up all my local frequencies (pd, fire, etc.) and now not picking up any of them. What am I doing wrong?
Yes, I just did. Thank you.Did you try the favorites list file in post #11?
