BCD436HP P25 programming
KB3WCU
I have a Uniden BCD436HP scanner and I added the ICORRS information for Lawrence County, Pennsylvania but I am not receiving anything. It will scan and say "ID Searching" but it never picks anything up. Is there another setting that I have to turn on to receive fire and EMS which is unencrypted in Lawrence County?
Thank you!
rwier
Phoenix, AZ
Thank you!
You may find Easier to Read BCD436/536HP Digital Scanner Manual helpful. And, you should find Easier to Read BCD436/536HP Digital Scanner Manual even more helpful. You probably want to see "Scanning" "ID Scanning" instead of "ID Searching". See Easier to Read BCD436/536HP Digital Scanner Manual
" ... I added the ICORRS information for Lawrence County, Pennsylvania ... "
really contains little information to assist in offering help. Are you using the "Sentinel" software? If not, someone else will have to assist you. If so, did you "Append to a FL"? See BCDX36HP Sentinel Software Manual lists (cut & paste to include "spacelists" in the URL). Did you turn on all "Service Types" associated with your FL? See BCDX36HP Sentinel Software Manual types (cut & paste to include "spacetypes" in the URL). Did you assign your FL a "Quick Key"? See BCDX36HP Sentinel Software Manual.
If you choose to use FLs, the above should get you in the ballpark. If you get stuck, repost your problems with a higher degree of precise syntax.
ofd8001
Louisville, KY
Are you able to hear the transmissions if you use the full database and enter your zip code? If so, it might be a problem with your Favorites List. If you can save it as an HPE file, zip it and attach to a message, we could look at it.
KB3WCU
Thank you for the replies! Yes I am using the Sentinel software and I am using Favorite Lists, all service types and quick keys. I'll also tried the full database based on zip code and it still doesn't work. I will try the firmware update and see what happens. Thanks!
KB3WCU
I installed the beta firmware of 1.11.23 and it fixed the problem! Thanks for the help!
