What firmware version do you have?
I know that the latest firmware is pretty buggy
F1 is favorites list 10-19, it should be F0:
S1 is system 10-19, it should be S0:
See this picture
D4: That means Departments 40-Departments 49.
It should be D0:, Departments 0-Departments 9
If you're running the latest firmware, upman needs to address this.
For now, try doing 01.01.04 and tell me if that works.
You don't need leading zeros for QK selection.
You do need them to show QK status.
1.1.4 shows status of FLQK's 10-19, SQK's 10-19, and DQK's 40-49 but if you press E/yes will toggle Dept 4 in System 1 in FL 1.
01.01.04 shows status of FLQK 1, SQK 1, and DQK's 0-9 and will do the same selection as above when you press E/yes.
The first way is easier if you know what is on or off.
The second way helps you see what's on or off.
