Hello,
My BCD436hp has been scanning a DMR Motorola TRBO for a local university PD and for some reason it just keeps dropping transmissions (I have DMR upgrade). Here is the site i'm trying to scan: George Washington University Trunking System, Washington, Multi-State - Scanner Frequencies I hear some transmissions, but i'll know i miss some because ill listen to the unit respond awhile later. Could it be my antenna is poor (I'm using the default one)? Could it be some setting I have wrong? I am very new to this and am having a difficult time understanding things like attenuator, modulation, or squelch. My squelch is set to 2. I turned on attenuator for all the TGID's. I turned modulation to auto for all channels. I have just set the radio to scan my favorites list at the university, so it's not like its having to scan 1000 TGID's. CAP is flashing on bottom of screen and by signal strength is also flashing at the top. It's not an encrypted channel because I can hear some transmissions. Sometimes it'll sound like someone is keying up on one of the talk groups but then its just white noise. I turned off battery saver. Can someone help better explain what settings I should be using to ensure that I am hearing all transmissions? Thank in advance.
