I have a 436HP and recently noticed that in UHF, signals that are normally strong are weak, but VHF signals are still good and at levels i would normally see. Ive swapped antennas and connector adaptors and other 436HP scanners on the antennas and connector adaptors, and the problem follows this one scanner.
one specific 462 frequency is full scale with my other unidens, on antennas and with this 436hp, it is not even one bar signal strength, very scratchy. just using this one freq as an example, ive tested it with other local repeater reception.
it also happens on the UHF (450-460) Trunked systems, DMR and LTR, same story, should be full strength, but is only no scale to maybe 1 scale.
the Connector center looks ok, (I would think if i had a bad scanner antenna connector it would be degrading everything)
I took apart and reflowed the antenna solder joints, (no change)
has anyone else noticed this weak on one band but not on another? easy fix?
