BCD536HP Audio output recommendations
tomas21
SoCal
I have recently reconfigured my home setup and trying to get the ideal audio listening configuration based on the unique BTL amp setup on this BCD536HP model has vs older models like the 996P2. I know audio via wireless is preferred but I would still like to also provide local audio wired.
I would like to hear the audio from the scanner in various use cases and would like to understand latest recommendations to not cause an issue.
  • EXT SPK (Rear port)
    • Use case 1 - Connect scanner Ext Spk to my Denon Audio Reciever (what is recommended?)
      • Option 1 - Using this ground loop adapter connected to back of scanner to a stereo 3.5mm to rca adapter plugged into Denon receiver
      • Option 2 - Using this mono to stereo adapter connected to back of scanner to a stereo 3.5mm to rca adapter plugged into Denon receiver
    • Use case 2 - Connect scanner Ext Spk to single external Uniden speaker (what is recommended?)
  • Headphone Jack (Front port)
    • Use case 3 - Connect scanner headphone output to Denon Reciever (will go this route if more idea vs. EXT SPK) (what is recommended?)
      • Option 1 - Connect 3.5mm stereo to rca to reciever
    • Use case 4 - Connect scanner headphone output to Uniden speaker (will go this route if more idea vs. EXT SPK) (what is recommended?)
  • Wireless
    • Use case 5 - Listening to scanner on a network computer or iPhone remote
      • Option 1 - Using proscan to pull in audio via IP address (works perfect)
      • Option 2 - Using Siren to pull in audio via IP address (works perfect)
jonwienke
More Info Coming Soon!
VA
Never connect a speaker out to a line in. The voltage can go way too high. Headphone jack voltage is about right.
But the digital streaming is far better. You don't need to worry about ground loop isolation.
iMONITOR
Silent Key
S.E. Michigan
I'm using Astatic 4" external speakers on all my scanners, plugged into the Ext Spkr jack on the back. It works very well, LOUD & clear!
TailGator911
Silent Key/KF4ANC
Fairborn, OH
I use a variety of speakers in the shack, and for the 536 I switch between Yaesu MLS 4" and the Astatic 4". I also used Astatic 4" speakers in my Freightliner for my Galaxy 10 & 11 radios. Those Astatics are indeed LOUD and CLEAR and perfect for a noisy big rig. No problem hearing any of my radios.
tomas21
SoCal
tomas21
SoCal
Thanks..looks like it is the Astatic 302-VS2 10W/8Ω Presidential External Cb Speaker.
Interesting reading this in the manual regarding the Ext. Sp.
NoClue48
Sun City, AZ
I use a Radio Shack Cat. No. 21-549A 8 ohm, 5-watt External Speaker that I've had in my shack for at least 25 years. Plug it into the external speaker jack on the back of most any of my table top radios and listening is good.
Recently ordered a Uniden (BC7) Bearcat 7-Watt External Communications Speaker to augment my Uniden SDS200; whose delivery is imminent.
The beauty of both of these is that they are un-amplified, don't require another wall wart power plug and emit sounds in the "voice frequency band"; (RS 300 - 3000 Hz), (BC 300 - 5000 Hz).
iMONITOR
Silent Key
S.E. Michigan
I use a Radio Shack Cat. No. 10-549A 8 ohm, 5-watt External Speaker that I've had in my shack for at least 25 years. Plug it into the external speaker jack on the back of most any of my table top radios and listening is good.
Both are also good choices!
tomas21
SoCal
Good input.. based on feedback I believe I'll go this route
Ror the rear EXT SPK. port I will either purchase a non amplified Uniden (BC7,BC15, or BC20) Bearcat to provide sound
For the front headphone I'll use a 3.5mm to RCA to my Denon Receiver
tomas21
SoCal
Update... using a BC7 connected to the EXT SPK port was the cleanest sounding. I tried the headphone jack to RCA on back on Pioneer receiver and sounded terrible... added the ground loop adapter and still didn't improve the sound.... at this point I will use the BC7 and not go the pioneer receiver route for local audio
tvengr
Well Known Member
Baltimore County, MD
You can use the Uniden BC23A amplified speaker. It has a built-in isolation transformer to avoid shorting the audio output to ground on the BCD536HP. You will need a 12vdc power supply.
NoClue48
Sun City, AZ
I'm using the BC7 on my BCD536HP and it sounds very good. A good, inexpensive solution to the muffled audio produced by the onboard speaker... my Radio Shack 549A is in use on my SDS200.
