BCD536hp NXDN Dickson County
hvac2670
I live in Dickson County Tennessee and have purchased the Uniden NXDN upgrade. When scanning i can only her dispatch and not patrol cars. Any ideas? Thanks
tnbound
Middle TN
I live in Maury County and Columbia is NXDN also and the Dispatch is clear and the cars are encrypted. It is not possible to unencrypt the cars.
Whiskey3JMC
DXpeditioner
Philly burbs 🇺🇸
Hi & welcome to the RR forums:
Assuming by your report that you're not able to pick up TGID 52006 here the first thing I would suggest is to ensure the Law Tac service type is turned on otherwise the scanner will omit all talkgroups with "tag" designated as such in the DB. If DB is accurate the aformentioned talkgroup is in the clear (mode "D") and should be able to be tracked unless something has changed since the submission was made. If the talkgroup were encrypted it would (or should) be listed as mode "DE" for full encryption or "De" (lowercase e) for partial encryption
W5RGP
Charlotte Tn
Thanks, i will look at these settings
i also live in Dickson County
nothing in dickson county is encrypted
make sure you have all the law service types enabled and you should be golden
also if you live closer to buckner park than charlotte turn off all sites except the dickson site
tvengr
Well Known Member
Baltimore County, MD
In Sentinel, go to the Edit tab, Edit Profile, and the Service Types tab. When Sentinel is first installed, only the Dispatch service types are enabled.
