BCD436HP/BCD536HP: BCD536HP where is "mass storage"
Mogman
Skidmore, TX
I am trying to update the data base in a newly purchased BCD536HP, the first step is "select mass storage" but for the life of me I cannot find it, it is not in the menu, also I do not get any reaction when I connect it to my PC, I already have the drivers for the 436 loaded and have no issues connecting to that radio.
The radio did not come with a USB cable but I do have an A-A cable
KevinC
The big K
Super Moderator
1 point
Is your cable a "charge only" cable? You should get a prompt on the scanner when you plug the cable into your computer.
nessnet
Eastside of Lake WA
Try a different cable...?
Mogman
Skidmore, TX
I will have to look for another cable, this came from a USB/IDE adapter so I am pretty sure it is a full cable.
I have dozens of A-B and tons of "micro" cables, this is the only A-A cable I have found so far.
Is there a way to load the data base onto the SD card with an adapter?
OR can I use an updated card out of the 436?
GTR8000
NY/NJ Database Guy
BEE00
Yeah, that's not going to work. The USB A port on the back of the 536 is for the WiFi module only, not for programming.
You need a Mini-USB cable for the front of the 536. Yes, old school Mini, not Micro. Any standard Mini-USB to USB A cable will work.
GTR8000
NY/NJ Database Guy
BEE00
Yes and maybe. Best to pop the microSD card out and use a USB adapter in the PC to program it directly, then pop it back into the scanner. That's how I program my 536, that USB port hasn't seen a cable in years.
Mogman
Skidmore, TX
OK, that is what I get not to read the manual, THANKS!!
I also did manage to update using the 436 radio, but now see the same USB jack on the front of the 536 DOH!!!
fxdscon
¯\_(ツ)_/¯
If your newly purchased scanner was brand new, from a reputable dealer.... check all of the packing material in the box. The BCD536HP ships with the correct USB cable in the box.
Mogman
Skidmore, TX
Not new, but happy with my purchase!
I just also picked up a Uniden BCD325P2, will be interested to see how it compares to the BCD436
fxdscon
¯\_(ツ)_/¯
Interestingly enough, I have the range set for 10mi and am getting traffic from 40mi or more away, all non trunking using ZIP
To get a better understanding of how range and location based scanning works, check under the heading of "UNDERSTANDING LOCATION, RANGE, AND SERVICES" starting on page 17 in this manual:
That manual is for the SDS200, but location works the same in other Uniden scanners.... the map version of location help wasn't included in the BCD536HP manual.
Check here also:
RMason
Colorado / Mississippi
The range you receive is defined by the scan range setting plus the programmed range of the Departments and Sites. I think of it as two overlapping circles.
From Understanding Range: https://www.uniden.info/download/ompdf/BCD436HPom.pdf
You will receive Departments/Sites that have a range equal to your scan range setting plus the programmed range of the Departments and Sites. For example, if your scan range is set to 10 miles and a Department/Site range is set to 30 miles, and that Department/Site is less than 40 miles away from your current location setting, it will be enabled in your Favorites List according to both range settings.​
Mogman
Skidmore, TX
Thanks for the responses, looking back at the manual it is actually very poor, it does not even have an graphical explanation of the front and rear panels and what everything is for (ports, buttons etc.)
