UNIDEN Support <noreply@uniden.com>
Nov 9 (3 days ago)
to me
Images are not displayed. Display images below - Always display images from
noreply@uniden.com
Dear Valued Uniden Customer,
The scanner can be controlled by an Android or iOS device using the Uniden Siren App found on the google/iTunes stores respectively. If you need to view it from a remote location, you would need to create a VPN for the system using a computer attached to the network We would not be able to assist you in setting up the VPN, but there is a good guide on the
RadioReference.com - Scanner Frequencies and Radio Frequency Reference forums.
The range for the scanner is based off of the transmission location. If a tower for a larger trunked or statewide system is in range, it may pick that tower up, even if it is just repeating a far-away frequency. If you are getting under 30 miles in range I would consider environmental issues, avoids, service types, deactivated lists, or not searching with scan. Metal walls, rock formations (especially containing ferrous metals), and being surrounded by structures can affect scan range. Depending on your area, you may need a larger antenna (available for purchase on
Police Scanners, Radios, Programming, Accessories | Scannermaster.com.)
If you wish to return the unit, please review our return policy located on our website
www.uniden.com and follow the procedures it describes. If you have additional questions please contact me back at
escan@uniden.com. If you put attn: Josh in the subject line, I will receive it directly.
Thank you for Choosing Uniden,
Josh
Uniden Tech Support
WHERE IS THAT GOOD GUIDE AT FOR SETTING UP A VPN????
NEED ONE FOR LINUX
