Isn't it stored on a chip
If you do this process will it not put back the preprogrammed systems?
Initializing the Scanner’s Memory
Warning:
This clears data you have entered. You cannot restore user
programmed data that has been deleted. You can, at a last step, restore only the
original factory data.
1. To initialize the scanner’s memory, turn off the scanner.
2. While pressing [2], [9], and [HOLD] at the same time, turn on power.
At that point anything you have programmed is gone.
60
You are given a last opportunity to keep the factory programmed data when you
see the question:
Restore Preprogram List? Yes=”E”/”No= ”.”
If you do not say Yes, the scanner is totally empty.
