djmorgan
I have both these radios and have downloaded our local bus company (San Antonio VIA Metro P25) system from RR. As far as I can see by reviewing the two radios via their menus in the radios themselves they are programmed the same. I also monitor this system on Unitracker and it shows the system to be APCO P25 with FDMA frequencies. This is a non-simulcast system but has two sites. I have locked out one to be sure I am comparing the same things.
The BCD996P2 tracks transmissions nearly perfectly. The SDS100 is barely functional. When a talkgroup moves to another frequency between transmissions the SDS100 struggles to follow it. The SDS100 rapidly switches between the control channel and the correct audio channel being used but won't lock on to the audio channel or takes so much time that you miss the transmission altogether. Sometimes it will catch it but not often. It looks like it is trying to figure out that the audio channel is an FDMA channel and which slot to lock on. I have a 7 second video of this but I guess it won't attach to this message.
Any ideas about what I can do to make this much more expensive SDS100 radio perform better than a radio costing half the price?
PS... signal strength is strong on SDS100, BCD996P2 and the Unitrunker and I don't have this problem on a very large regional Project 25 Phase II system (that does not use FDMA). Thoughts very much appreciated!
