I believe there is a caveat that the 996P2 must be on V2.18 or higher!free scan does not work with with the 996 p2 .
i have tried it numerous times. tells me its not supported
My bad...Freescan must be version 2.18 or higher!how can you find that information ?
Do some scanners have bigger open squelch area before the static than othersIts gonna be displayed in the far upper right on the screen....
YES...varies widely!!!Do some scanners have bigger open squelch area before the static than others
I never had a Uniden to know how the squelch, My RadioShack Pro-2015 the knob went further before the static and the Pro-197 is 55% before staticYES...varies widely!!!
Volume and squelch controls used to be physical pots...now they are rotary encoders. Act the same, but no really! Thus the difference in the older radios and newe!I never had a Uniden to know how the squelch, My RadioShack Pro-2015 the knob went further before the static and the Pro-197 is 55% before static
Would the Uniden be better than the Pro-197 on the squelch, I been looking at the Uniden but I can't find a picture online on where the static starts to compare the twoVolume and squelch controls used to be physical pots...now they are rotary encoders. Act the same, but no really! Thus the difference in the older radios and newe!
My 996P2 does work with Freescan although I now use ProScan. While Freescan will work with the 996P2, Freescan does not support DMR, NXDN, etc.free scan does not work with with the 996 p2 .
...With exception of no support (as noted) for DMR and NXDN systems, FreeSCAN does work for basic programming with the P2 scanners, as well as the previous "T" and "XT" scanners.My 996P2 does work with Freescan although I now use ProScan. While Freescan will work with the 996P2, Freescan does not support DMR, NXDN, etc.
Just tried Freescan with my 996P2 this morning to get this screenshot...
View attachment 141178...
Would it be at the blue, yellow are orange
Would you happen to have a picture of the 2 setting since I don't have one yetThe BCD996P2 normal squelch setting is 2.
Here ya go…
It’s displayed on the screen…as the squelch control is an encoder and not an old fashioned pot I’ve seen the physical knob position vary…
What is oldest scanner that uses pots that has Pl tones or that can be setup by programming softwareHere ya go…
Can you change the squelch with programming software, that's the first scanner I saw that tells the squelch position how many settings does it haveHere ya go…
Yes you can. It has settings of 0 - 19.Can you change the squelch with programming software, that's the first scanner I saw that tells the squelch position how many settings does it have
Actually that's what I used to think but I've been told an encoder would be too expensive, it's acutally a cheap rotary pulse switch which has been known to get dirty and fail over time with heavy use. But I never had one fail in my lifetime as I seldom need to adjust it.the squelch control is an encoder and not an old fashioned pot I’ve seen the physical knob position vary…
